Building out my system, where/how best to tie B2B in 2019 Sprinter with Aux Battery?
brent.carroll
Hi all,
First time poster here. I tried this question over at Sprinter Forums and got little traction. Then, I heard about Will Prowse and this forum!!
Subject line pretty much is it, my aux battery is under the hood. I have been working directly with Victron to spec out my system and I expect components to start rolling in pretty soon (my basic system is 960W solar, 600ah Lithium, 5KW inverter, chargeable by shore power, solar, and well, the alternator I hope). I feel pretty good with just about everything so far (Victron provided a LOT of guidance), but tying into the van electrical is something I am but worried about - I don't want to risk what I perceive as a novice tinkering with a pretty sensitive system.
Any advice would be most appreciated!
~Brent
Hi all,
~Brent
DC to DC charger needs to come off the battery or pretty close to it
The NCV3 with aux. battery option should have a battery isolating relay installed under the drivers seat. There is also a connection point here for running items off of the factory auxiliary battery.
I would strongly recommend against tying into the auxiliary battery system. Mercedes also recommends against tying in more than 100aH of lead acid batteries to this connection point due to potential damage to the alternator.
I would recommend tying directly onto the starter battery with a battery cable to a DC-DC converter to charge your lithium batteries. The NCV3 has a factory terminal fuse block on the battery. I would start there and check if there is an open port on the fuse block. If there is, I would tie a new battery cable onto that point and take that to your DC-DC converter. These factory fuse blocks utilize MIDI fuses.
If you go with a Renogy DC-DC charger, you can tie the turn-on wire to a factory connection point under the drivers seat. There is an "engine running" terminal that will only turn on your DC-DC charger once the engine is running.
If using a DC to DC charger would it be ok to tie into the “under drivers seat” connection? With the charger everything would be rated and controlled to a specific ampage (30 ish depending on the charger).
Is that line fused and if so what with? Wonder what wire runs to it and from where exactly.
Here's one example of a connection to the starter busbar/fuseholder: DIY installation tutorial: Enerdrive DC2DC+ charger + Sprinter van + Lithium house battery
You'll also likely need / want to connect to the 'engine running' D+ signal that's present on terminal 1 of the "auxiliary electrical connector" EK1 under the driver's seat, so the charger only operates when the engine is running.
I can confirm the above is correct for an Australian NCV3, w/out auxiliary battery (we have this setup with a Renogy DCDC12 40A; w/ a 60A MIDI fuse on a spare slot on the starter busbar).
I would not tie directly to the power terminals under the drivers seat. I don't remember what the body builders manual says but I would not personally put more than a 10amp load on them.
Thank you everyone - this is exactly the sort of help I needed! Just heard from Victron today and everything will soon be on its way.
... I don't remember what the body builders manual says but I would not personally put more than a 10amp load on them.
For the NCV3, the auxiliary electrical connector (EK1) provides
  • engine running (D+) (10A)
  • battery direct (25A)
  • ignition on (15A)
ref: Sprinter Body & Equipment Guideline (BEG) 2016/2017, section 7.4.7.
The best location to connect a DC-DC charger above ~20A is at the busbar / distribution block attached at the starter battery itself. You'll need a MIDI fuse.
