Here is an idea to gauge where it is headed.
To deliver a particular amount of power, need to achieve the force you've calculated.
Hold a pair of magnets spaced apart as far as the air (or copper, or plastic or OSB) gap they will see in this alternator.
Measure the force between them. Multiply by number of magnet pairs around the armature. That is an estimate of the force the armature will experience. Multiply by radius, and use that as foot-pounds.
From Holy Bee's equation, estimate watts. It seems if you don't get 700 pounds / 96 magnets = 7.3 pounds/magnet with that airgap, you won't be able to get 6000W at that RPM. 0.73 pounds/magnet for 600W.
If the result is too low, try reducing that large (1"?) airgap to 1/16th of an inch. And use a steel band as pole piece from outer surface of each magnet around to outer surface of other magnet. (i.e. make a pair of tweezers with magnets pinching together the tip. Functionally, a horseshoe magnet that is flexible.) Measure the force required to hold tip of tweezers 1/16th of an inch apart.
If results are good now, you need magnetic pieces inside the stator windings to reach from almost touching one rotor magnet to almost touching the other. And, disc pole pieces to gang the outside face of armature magnets.
Note that the forces you measure will attempt to bend armature discs so they crash into the stator. And vibration will build, helping to close the gap. They should be as close as possible without every colliding.
