John Frum
Tell me your problems
- Nov 30, 2019
- 15,224
My APC SurgeArrest power bar shows "building wiring fault" appears to be all outlets on one phase.
I have no idea how long this may have been going on as the power bar is usually fairly inaccessible.
I didn't test them all because some are a giant pitb(where b stands for back) to access.
No faults are detected on the opposite phase.
I also have an older model APC SurgeArrest personal and it doesn't show a fault on the same circuits that showed errors.
I have an outlet tester which shows correct wiring.
I checked with my dvom and the only thing of interest is ~1volt between neutral and ground which is consistent across both phases so probably unrelated.
Any ideas?
Any further tests?
I guess I better get an electrician on the case pdq.
Any ideas?
Any further tests?
