Hi,
When using more than 6 batteries (EG4 280AH indoor), EG4 recommends the use of an external bus bar.
Following their specs, it doesn't look like fuse or DC breakers are required, is that correct?
Since I can't really locate a bus bar for my setup, I'm considering getting them made, started thinking about it and realized I had some questions.
Assuming 12 of those batteries feeding 3x Flexboss21, each Flexboss21 capping at 250A max realistically the max theoretical current in the bus bar would be 750A. Practically, it would much less than that as the various lugs would be strategically placed. For instance if the bus bar is 16" long, the first inverter's lug would be at 4", second at 8" and third at 12". and in between each inverter lugs, you'd have 3 pairs of lugs for the batteries (all assuming the wires between batteries and bus bar are all the same length). So really, the max current in the bus bar should never even reach 500A.
But I digress, assuming a Max current of X, you can use cross sectional data to assess acceptable values. but what about the length? how does the symmetry (like I was suggesting above) play into the bus bar design and is it important? From all I've read, the emphasis really is on the length of the cables (bus bar to battery) more than the bus bar itself.
