I have made 90 degree Cu-ETP copper busbar 4mm*25mm with M10 hole on each end, for the positive cable to exit the battery box more cleanly.
Before this bus bar i have 70mm2 cable, which goes to battery disconnect switch with M10 bolt, then comes this bus bar, and after the bus bar comes 70mm2 cable again (m10 tinned copper lug).
When running heavier loads for 20-40minutes, this busbar warms up, not so much you couldn't hold it, but still. All the other connections on the battery and elsewhere are cold.
What would be solution to stop it warming up? Some sanding with 800 grit, then putting some antioxidant paste over and tightening the bolt hard?
