Bus Bar / Shunt connections - How to improve the connection ?
EPicTony
NE Ohio
I have 4/0 cable going to my battery racks. I have the charging current set to 230A which is the limit for 4/0.
During charging @230A the wires get warm but the connection points at the bus bar and shunt get a lot hotter (almost too hot to touch).
I have torqued them pretty tight and don't want to over torque them. Is there some way to insure a better connection ? I'm sure the heat is produced by the added resistance of the connection and not undersized wire. Any tips ? Thanks
having just dealt with the busbar on a eg4 server rack, I am not sure if they have upgraded this since. But the one I was dealing with had what looked like brass inserts for the bolt to connect to. As in the wire terminal had a brass insert in between it and the busbar. I believe this to be a version 1 or whatever of it. AS the eg4 batteries are also the version one.
We removed all the inserts and mounted the battery terminals with bolts/nuts directly to the busbar.
Do your busbars have a insert in the way?
No the connections to the bus bar are direct. The EG4 busbars are good no temperature increase there. The temp increase is on my smart shunt connection (4/0) and the short 5" bus bars where the inverters connect to the 4/0 battery cable.
All the usual stuff: -
Thoroughly clean the contact area of the bus-bar and your lug. Add some Noalox or similar zinc-loaded contact gloop if you wish.
Are your lugs of good quality (copper)? How about the crimping itself, cheap lugs and tools lead to poor connections.
It's also worth noting that shunts can get quite warm.
Most shunts are 75mV drop at rated current.
So, our 300A shunt would be .00025 ohms. Sounds tiny, but at 250A that's going to dissipate 250^2 * .00025 = 15.6W
Unfortunately(?) our packs are full (it's just about 1pm) so I can't go and check just how warm it is.
