I would be more interested in how many amps are going to/from each battery.
Agreed. What are you running off of this battery bank ?
An off grid homestead. So everything that I can.Agreed. What are you running off of this battery bank ?
800A to or from the eight batteries max (so 100A per battery) by their design and their cable limits.
My system limits me to putting about 65A to each battery unless I get more solar and I'm taking out even less than that due to inverter limits.
We're interested in the amps to each battery as that is probably a better judge of how balanced the cables are than voltage is.
Victron Quattro 15K.I meant to ask what inverter and the peak power output of it.
Make and model should be enough info.
In my if thare is cell in balance error and only one cell is in that balance volts and the other notI'm now seeing a disparity in cell voltage of .008 but I have no idea if that is considered a lot or not. The BMS will throw a cell imbalance error at some point, but I don't know what the delta is for that error since the manual doesn't specify. I'm guessing .008 isn't that bad. Hopefully the gap doesn't continue to grow larger.
.008 is often below the threshold at which the BMS will balance. On my JBD BMS the default threshold was .015. My new JK BMS has .010 as a threshold. The cells have to be above a certain voltage before balancing will commence.
I have been rather unimpressed with the Victron VE.Direct connections. I swear they pull out if I look at them funny. I saw one suggestion to secure them in the terminal with hot glue. I just use strain relief on the cable in such a way that there's some force from it to hold the connector in the terminal.
Are your connections mobile in your RV?
Side note, just noticed you have a Polaris Ranger, have you looked into the Kinetic model by chance?
I use those cable on the mppt.Yes. But even sitting here in my garage the connections aren't very secure.
Nope. Wasn't aware of it until you mentioned it. New name for their electric version.
Yeah, it also has lithium. Test drove one, it moves quick.Nope. Wasn't aware of it until you mentioned it. New name for their electric version.
It appears that the cables you are using to plug into your MPPT are DIY cables, with self assembled JST sockets, with "clips" on each side. My DIY cables were extremely difficult to remove after they were inserted into the MPPT socket.I use those cable on the mppt.
And compleet usb divice hang on that cable.
Than i life on a boat and that boat always go up and down with the waves.
And it still sit in one place and do not fall out.
It have clip that secure it
Get the victron wire box for that mppt, it has clamps to hold the wires in place and it shields the wires as well. Not very expensive and looks goodIt appears that the cables you are using to plug into your MPPT are DIY cables, with self assembled JST sockets, with "clips" on each side. My DIY cables were extremely difficult to remove after they were inserted into the MPPT socket.
However, my Victron OEM "VE.Direct to USB interface" cables fit into the sockets of my MPPT's fairly loose, and I worry about the cables falling out of the MPPT sockets as I bounce along in my cargo trailer.
I am stlll trying to figure out how to better secure the cables so that the cables do not fall out of the sockets.
Replace the victron oem connectorIt appears that the cables you are using to plug into your MPPT are DIY cables, with self assembled JST sockets, with "clips" on each side. My DIY cables were extremely difficult to remove after they were inserted into the MPPT socket.
I just ordered one wire box for $31.83 (including tax). Thanks for the lead!Get the victron wire box for that mppt, it has clamps to hold the wires in place and it shields the wires as well. Not very expensive and looks good
I am pretty sure I had the correct size JST connectors.Is it possible you used the wrong pin pitch... the JST connector comes in different pin size and spacing..and they look the same
You could bend them a bit, using a bench vice and a cloth to not scar the lugs. Do this in increment though as you don't want to put a line in the lugs, which happened the first time I tried it on regular flat lugs. I did this cause I hated buying 90° and 45° lugs separately as I am setting up my system on cart with 3 separate levels. Some of my bends are only 15°, which sometimes makes a huge difference in contact area, especially when using 4/0 AWG with short lengths.I put these on the bus bar and the entire lug is flat on the bus bar so I think the contact should be good. They are wide for sure. Two of them on the bus bar are flush with each other and touch. But when I set it up there won't be two of them next to each other so that won't happen.
Edit: actually the bottom of the lugs hang off the bus bar just a bit and width wise they don't quite touch (the flex ones did though).
