Yep, that's what I found. Would love to see the information that MBR posted. I would trust that Bluetti would have the correct information posted... I hope.
Which solar panel would you recommend?
Looks like they have the two pack for $171.99 vs $87.99 for the one pack.I just bought one of these panels and will be buying another to make a foldable duel panel setup...
Was there a reason you bought the 1-pack vs the 2-pack?
I know it isn't much savings but still $4 is $4.
I am going to pull the trigger on the AC50s this Monday.
It is official.
I bought a AC50s using my brand new Chase Freedom Flex credit card --- the credit card which gives a sign-on bonus $200 off $500 plus 5% rewards the first year on groceries up to $1500 in rewards.
Yahoo!
It is too bad that the 5% rewards with the Chase Freedom for Amazon ended Sept 30.
It would come in handy for buying the panel but I want to make sure I get the AC50s first.
You have the Chase Amazon Rewards credit card.
I have the regular Chase Freedom which isn't available anymore since it looks like Chase is transitioning to the Freedom Flex.
Chase Freedom has the revolving 5% categories every quarter.
Q4 2020 is Walmart and Paypal.
Q3 2020 was Amazon and Whole Foods.
I wanted to buy two of these to use with my AC50s, however, the VOC is 26.4 volts, x2 puts it over the max for this, correct?Looks like they have the two pack for $171.99 vs $87.99 for the one pack.
It's the Open Circuit Voltage. I believe that you have to stay within the limits for each panel - The AC 50 has a range between 14 and 40. Someone else told me that if you go over, it will most likely damage the panel.. Hope this information is correct..Vicki,
As I understand it, the AC50s is exactly the same as the AC50 in terms of specifications except that the 12V out is regulated.
I am new. What does VOC stand for?
Exactly - It is confusing with the parallel and series connections. What I am having a problem with is finding a foldable/portable panel within the VOC range, with a kickstand, can be run in parallel or series and with MC4 connectors. If it doesn't have the proper cables, then you need to know what extra cables and connectors you'll need. Not all of this information is given on Amazon on the panels I am looking at. I'm overwhelmed! I have been watching Hobotech and researching this for hours!I just read the manual https://cdn.shopifycdn.net/s/files/..._User_Manual_16.061.00248-01.pdf?v=1598865324
and it says that the maximum is 40 VOC when asked about having panels in series (page 13) .
So you are right.
Hobotech did a review about putting 80W panels in parallel. I don't know how that would work with the AC50s.
