thealaskan
- Mar 3, 2020
- 129
I have 4 LV2424's in split phase, 2 in each. I have a separate charge controller from my solar panels. I have 4 BYD 24 volt plug and play units with which have separate BMS's in parallel.
I have had issue with the 24/7 daylight that the LV's, (I think would not go into grid charge because of the panels sending voltage signal.) So I put a separate charge controller in.
Because I've been looking at the past records now, prior to the CC, I've been noticing a fall in capacitance.
Where as 26.8 volts may be held for hours in the past, has turned into 26.5 volts for minutes after charge.
Settings are 27.5/23.5 30amp User no lithium available in settings.
Should the pack's degrade this quick?
Bought a Battgo tester, did 2 so far checked ok like the BMS was doing its job.
Do the Battery's have to be wired in parallel prior to the BMS's?
Is the BMS for charging puposes only?
