ASword
In planning an inverter-based system with a generator and AC coupled PV, it’s pretty clear that having a quick and easy (ie spouse compatible) means to disable the fancy stuff and fall back on the existing grid/ATS/generator system will be essential. Ideally one big “pull this” lever.
I think this means switch primary panel to inverter line to primary to ATS, inverter to secondary panel line to ATS to secondary, and generator to inverter line to generator to ATS. So that 3 big 240v circuits that need to be cut over, preferably in an interlocked fashion. Plus the generator control lines, although that might be done just by hitting the rapid shutdown on the inverter. There are undoubtedly details around things like shared grounds/neutrals that need to be taken into account.
I haven’t yet found any switch that can do this. Any pointers?
