WorldwideDave
Now that I know what kind of cells are in my 200Ah 12v CHINS battery:
GFB 3.2 V
320Wh
100Ah
48173125
OALCBA3510000D
A search online reveals the C rating
Looks like it is .5 C per cell.
There are 8 cells total making it 2 series 4 parallel I think.
Because it is a 200 Ah battery, if it were 1C it could discharge 200 amps in one hour if BMS would support it I believe.
If it were 2C rated cells it could consume 200 amps in 30 minutes I believe.
Therefore - and please correct me if I’m wrong - the .5 C rating of these cells should mean a discharge rate of no more than 100 amps per hour. Is that correct? Or I could drain it no faster than 100 amps over a two hour period from full to empty.
Does this sound right, or does having cells in series play a factor?
Honestly I didn’t know what to expect when opening it. I thought there would be 4 big batteries not 8.
GFB 3.2 V
320Wh
100Ah
48173125
OALCBA3510000D
