Yes, they are good enough, typically you have to use a size lower than the tool suggests and you can't do it all in 1 go or it leaves a barb...Does anyone have any experience with this style of crimp tool? It looks good in theory, but not sure if it actually makes the cold weld.
Cable Lug Crimping Tool for Battery Cable Ends,8-1/0AWG
I used that hammer crimper but I didn't use any sort of hammer. I put the crimper in a vise and squeezed it to make great crimps. So much easier than whacking away with a hammer.I haven't used those but I did get this one for my battery connections. It worked great.
https://www.amazon.com/TEMCo-Hammer-Crimper-Tool-Warranty/dp/B00E1UUVT0
I just received this one from Amazon. Took a look at the cables with my Renogy inverter and they show the hex crimp, but I'm sure they're using something industrial.
Alternatively, get the TEMCo Hydraulic crimper TH1818. I did. It is an indent crimper like the TH0012 tool above.I like this one much better.
Will recommended it in some of his battery builds, and I use it on my bigger projects.
So much faster than hydraulic.
I haven't seen anything like that since the Spanish Inquisition.
cuts cable like butter. Cuts so smoothly I wish I could use it more.If I had the ability to machine it, I would build a cutting die for my TEMCo hydraulic crimper.
What kind of wire and what awg?cuts cable like butter. Cuts so smoothly I wish I could use it more.
I have the smaller version of that, and it cuts like butter.What kind of wire and what awg?
Big difference between welding cable and xhhw.
I doubt the product description can tell me what type of wire at what gauge you were cutting so smoothly.take a minute out of your busy day and maybe look at the product instead of upping your post count.
