Apologies if this has been discussed...(probably a dumb question)
I have a 24V LiFePo4 battery bank with two batts in series. The two posts that are not connected in series will be used for load and connect to a stand alone inverter. I have a stand alone solar charge controller and a stand alone converter/charger that will need to connect. Question: Do I land these three components on the same battery posts? Or should I connect either (or both) SCC and Charger to the posts that are in series? Does it matter?
