Calculated cost to run a generator
Dinobot248
Ohio valley
I wanted to share my calculations to compute the cost to run a generator with gasoline, propane and natural gas.
Previously, I was not able to find any reliable information on an inverter generator running natural gas and what information that I did find, used fuzzy math
Each generator is different and the costs calculations are for the specific generator listed below under Reference section below. Using the specifications for the generator, I was able to find the cost per kWh for my area. Your mileage will vary.
Input costs
NG (MCF) $10.00
Propane - retail (lb) $1.00
Gasoline (gallon) $3.00
Type of Energy Cost / kWh
NG - 25% load $0.2692
NG - 100% load $0.1698
Propane - 25% load $1.8150
Propane - 100% load $0.9433
Gasoline - 25% load $0.8186
Gasoline - 50% load $0.5412
with low idle technology
Gasoline - 100% load $0.5501
Grid / POC $0.2500
Reference
Manual for Genmax 11,000w Tri-Fuel Inverter Generator
Feel free to use the links below or find the webpage yourself
Link to website
GENMAX GM11000iET 11000 Watt Tri-Fuel Inverter Generator - Remote Start CO Sensor
Link to PDF
6800.J35.GEM.02.02 GM11000iET三燃料变频发电机说明书 新版彩色插图 V1版 20240226.cdr
Probably belongs in the Fuel Back-up Generators board, but nice thread. I have wanted to actually do this with my Champion tri-fuel inverter and see what kind of energy output I get per $.
I presume under basically any circumstances, NG is likely to be cheaper than propane grill tanks or gasoline, but in your case, it's a fraction of the cost, which is awesome.
Hoping I never have to put gasoline in my Champion to begin with, but tri-fuel is where it's at for preparedness!
