Doug Hutcheson
- Nov 13, 2020
- 3
I am considering building an off grid aquaponics system with 12000lph air and 12000lph water being pumped 24x7x365.
Best use of energy seems to be 48v DC. I have found a 48v 12000lph water pump drawing 750w and a 48v 12000lph air pump drawing 202w. These are examples only and I am still looking.
Assuming these loads, I calculate my daily draw to be 22848w and I am in the Philippines where it is rainy so I estimate I need 4 days of storage, or 91392w hours.
At 48v this comes to 1904 amp hours. Allowing for LiFePO4 batteries at a discharge limit of 80% and rounding up a bit, it seems I will need 2500 amp hours of storage.
Am I on the right track so far?
If so, how do I source the cells I need and connect them to build this sized battery?
Furthermore, I am working on 5 sun hours per day. To charge 2500 amp hours of 48v storage in 5 hours seems to me to require PV supplying 5000 amps by 48 volts, or 240 kilowatts, but that doesn't sound right. What am I doing wrong?
