Steelart99
Introduction: I started purchasing components for a solar system with an admitted ignorance of all the parameters that needed to be evaluated. I currently have an EG4 6000XP Inverter and an EG4 Wallmount indoor lithium battery (280ah) and I am happy with those choices for my current household load.
My initial calculations (flawed) indicated that I should use 400W panels in two strings of 8 panels to provide 6400W of power. Note: My panels will have to be about 350-ft from my inverter. Yikes!
I ended up purchasing Aptos DNA-108-BF10-400W, bifacial panels (not delivered yet) with plans to set these up as noted above.
Solar panel descriptions and spec sheet at:
https://solarguyspro.com/products/a...ck-up-to-500w-with-bifacial-gain-dna-108-bf10
Issue: When I got a bit more educated from this forum, I found out how much panel operating temperature needed to be taken into consideration. I did the first set of calculations below and realized that I perhaps should have obtained more panels to feed the inverter up to it’s designed input parameters … See the second set of calculations.
Questions: I would appreciate a quick review of my calculations and my thoughts associated with increasing my solar panel count.
- First … am I assessing performance correctly through these calculations?
- Am I correct to assume that I could add 4 more of the same panels (Total = 20 panels) to better utilize the 6000XP?
- Is it correct to say that in a 20-panel configuration, there is no advantage to having bifacial panels as the added power gain would not be used by the 6000XP?
- Note: My temps range from -27F (-33°C) to about 100F (37.8°C) ---- Colorado
- Note: Temperature Coefficient of Aptos Panels: Voc = -0.30%/°C
- Temp Differential from STC = 25°C - (-33°C) = 58°C
- % increase = -0.30%/°C * 58°C = 17.4%
- Voltage Increase = (% Increase/100) * Voc
- Note: Open Circuit Voltage of Aptos Panels: Vvoc = 37.18V
- Therefore, Voltage Increase = 17.4/100 * 37.18V = 6.47V per panel
- Max Voc = Voc + Voltage Increase
- Max Voc = 37.18V + 6.47V = 43.65V
- 8-panels Max Voltage = 8 * 43.65V = 349.2V
- This is well under the 480V voltage limit on the 6000XP
- Note: The Vmp at NOCT for these panels is 31.28V
- String of 8 panels would be 8 * 31.28V = 250.2V
- The 6000xp is looking for a nominal 320V so 250V is a bit low but should work
- If the panels were generating a nominal 400W each, then the total power would be 16 * 400 = 6400W which is below the max utilized solar power for the 6000XP
- If the panels were generating 500W each (bifacial), then the total power would be 16 * 500 = 8000W which is equal to the maximum utilized solar power for the 6000XP
- It appears that I might be able to use 2 sets of 10 panels in series i.e., 20 total panels
- Max Voltage (at -33°C) for 10 panels in series = 10 * 43.65V = 436.5V which is still under the 480V voltage limit on the 6000xp
- The Vmp at NOCT for these panels is 31.28V. A string of 10 panels would be 313V which is close to the nominal MPPT voltage of 320V for the 6000XP
- These panels are bifacial with a nominal 400W max power with just the front side and 500W with max backside power gain (likely to rarely happen)
- Max Power of 20 panels at 400W = 8000W; 20 panels at 500W = 10,000W
- Note: Maximum utilized solar power on the 6000XP = 8000W with a maximum solar input of 10,000W
- Based on the above calculations, 20 panels at nominal power (400W) will max out the utilized solar power on the 6000XP with no added advantage from the bifacial gain at 500W
- However, the gain in Vmax up to 465V by using 10 panels per string makes for more efficient transmission along the 350-ft run from inverter to solar panels
