I missed a few days, and we have a lot of posts here now.
I am still trying to read and understand all the new rules in the NEM 3.0 document. It's quite obvious they are upset that they will be selling less electricity and they want to make as much or more money from people NOT using their electricity. It really is a scam.
If they decide to mess around with the rate structure and give everyone a fixed few for having the grid available to cover maintenance cost, but then charge LESS per KWH, I guess that would be fair. But what they are trying to do is give all of us Solar users higher rates, AND charge us fixed fees when we don't use power from them. That just seems wrong. If we do go to "Zero Export" we should be charged the same as a non solar customer for the power we do end up using. Don't pay me anything for export, but then don't jack my rates to have power either. I was quite annoyed by the loss of my tiered billing. When my lowest tier was just $0.12 per KWH, and now my cheapest TOU rate is $0.22 During most of the year, I would have been able to stay totally in Tier 1 with my solar install, but thanks to forced TOU, I am paying about 50% of what I did before, while using just 25% of their power. So my cost per KWH from So Cal Edison is essentially double now. And that is just NEM 2.0
With the proposals for NEM 3.0, it looks like my bill could be as high as it was pre solar. If I "Decommission" half of my Enphase array, and change that to DC to charge my batteries. I might be in a much better position. Then my system will only be 1,920 watts of grid tied solar inverters.
The whole issue of wanting us to add batteries makes the issue get very strange. I read the rule as how much solar panel, not inverter capacity. And I am 25% over paneled on my micros. So that does make a difference. When set to "Zero Export" a battery inverter should not add to any "grid benefit charges". And the amount of solar we have should not mean squat to them if we are not exporting. I can see their point when we push power out, they do need to deal with that power, but it is becoming plainly obvious that they want to just make Solar no longer cost effective so people just buy the power from them and don't bother with solar panels.
Clearly, I need to read over the rules a bit closer to figure out how to work the system. I also may end up writing a few letters. California as well as the federal government has been pushing us to go solar, and now they want to penalize us because it worked and people did it. That is just plain wrong. It is like when they pushed us to reduce water consumption here. Everyone put in the low flow crap, and then the water company jacked the rates to make our bills the same while we use 30% less water.
