I have a smaller camplux water heater mounted inside a 26’ RV
No, that is not recommended but it’s been fine a year and a half or two. I needed it warm for winter usage.
Please point me in the right direction if this is the wrong place to ask this. I am installing a camplux propane instant hot water heater at the cabin and wanted to run some things by you. Outdoor shower will be at the back of the house and the sink is at the front. Was going to mount the unit on the west side of the house where there is plenty of shade. Any recommendations?
I put a 12V-3VDC converter on a switch instead of using batteries but batteries can last a year.
Run a good whole-house filter. It can get munged up and the waterflow switch can stop shutting of flame when water stops- but it lets you know the overpressure relief valve is functioning.
The power on a switch : I use a rotary 15 minute timer. This is a safety factor since the flame not shutting off has been a common failure across three units. The timer lasts longer than my shower but I physically turn it off so it can’t fire up for whatever failure it might have.
I plumbed it into the camper hot water lines. I keep it turned down for temperature and don’t mix cold at the shower valve because it can make 150* water. I have a ball valve on the feed and attenuate water volume that way.
Run a water filter ahead of it. The passages and switches are too small to deal with stuff running through it.
I used bsp to npt adapters and screwed swivel pex fittings into those. I’d advise the same for you and just feed your kitchen from a tee.
When my first one failed it was $110 to replace. The second one quite a lot more. Now I think they’re like $225. Doing that every year is annoying.
I contacted service a couple times and I think they are helpful but I just needed hot water and Amazon was two days rather than shipping one out and waiting for it to be serviced and returned. I didn’t return or replace this current one. I just kill the power if I hear the flame not shut off. Usually the high-temp kills it but sometimes it won’t and over pressure release lets off steam. Impressive. Not.
But the cost to run it for hot water is like basically nothing.
