I have a 200W BougeRV solar panel and 30a BougeRv charge controller. I used this with 2x80ah marine batteries to run a 12v fridge (55w when cooling). I have a cheapo voltage current meter attached to the negative battery terminal and all negative wires (the charge controller and the fridge) attached to the other end of the voltage meter. Everything worked fine and the batteries were fully charged each night and only down to 12.5v in the morning.
I recently bought a 100a lifepo4 battery from DC House via ebay. I hooked this up to the same solar panel/ charge controller/ voltage current meter and changed the controller settings to Lifepo4. I came out mid day to check on things- the solar panel was in full sun and both the charge controller and the voltage current meter read 17v. I immediately disconnected the solar panels. I checked all my connections and tried again the next day and had the same problem. I then swapped out the BougeRV 30a controller for a generic 30a controller. I came out mid day again and both the controller and the voltage current meter read over 15v. I disconnected the solar input. As I checked the connections, I found that the positive MC4 connector was not snapped all the way in. I double checked that both charge controllers were set to charge lifepo4 at max of 14.6 volts.
Now I'm trying to figure out where my problem is. Is it two bad charge controllers? Is it a bad Lifepo4 battery? Is it a bad solar panel? A bad solar panel connection or connector?
Any help appreciated!
