Thank you. That is what I was wondering. The 12v converter will need to connect to the bus bar with an SSR in between.The bms B- needs to go to the battery direct, not via a shunt.
The shunt will generate a voltage difference when current starts flowing. And this in turn will trick/fool the bms.
So, if you want the bms to behave correctly, no shunt between B- and battery.
Sorry how is this charge protection implemented?There is charge protection only from the higher volt charger. The lower voltage charger should cut off before any runaway happens, I have a separate relay I might use.
Through the BMSSorry how is this charge protection implemented?
Ok I see it now.Through the BMS
