Can a jackery explorer 3000pro be charged via the solar input ports with a battery bank?
chiefcook47
Arkansas
Is this even possible?
This unit can accept 11 to 60 dc volts. Will it charge faster at the highest voltage? I want to charge with a battery bank when no or low light conditions exist. I can use a dc to dc converter or charger to charge at the best voltage. Would i need a charge controller to prevent a high amperage inrush?
I want to charge via the solar inputs if possible because the 12v input is very slow.
The only other idea I have is a pure sign wave inverter, but that would be less efficient.
