Jsh700r
Hello all,
Can the Victron BMV-712's be used as a low voltage disconnect by using its relay function to turn on/off an inverter?
I plan on upgrading my 48VDC system to lifePO4 with a 16 cell string of 280AH cells, 100A BMS, Victron 150/35 Charge Controller and a BMV-712 monitor with temp sensor. I haven't figured out the best way to operate a low voltage disconnect but I am thinking the BMV-712 has a relay function that could turn on and off my Cotek 2000W inverter (SK2000-148) that has a three position toggle switch (On, Off and Remote). Would that work and be a good solution for a low voltage disconnect?
Any advise would be much appreciated,
Thank you,
JSH700R
Thank you,
JSH700R
