Can anyone assist me with a saj hybrid inverter and seplos v3 bms.
ddonq1412
I have been asked to have a look at an inverter that only seems to charge and discharge at 2.5kw. the inverter should be able to pull higher around 5kw. The inverter does read the battery BMS. I think it's on the wrong profile on inverter. The solar installer advised there is other profiles but are fixed. Not sure I believe them or not. Is there a better profile on inverter and battery to use.
