dads_old_hypercube
- Dec 30, 2019
- 1
electrical v2
bonus van layout (thought about B2B but later decided against it)
Vehicle is a 1993 Toyota HiAce imported from Japan, so the battery and engine are on the left side, driver on right.
Components:
Charge Source:
Minimum Loads:
Maximum Loads (worst-case):
Daily Minimum Load:
Daily Maximum Load:
Based on a battery life of 1,200Wh/100Ah, I'd run it at about 30% capacity each day at minimum, and 80% capacity on a worst-case scenario day. Running only minimum loads then, I could get by for about 3 days without recharging at all.
Questions:
Components:
Charge Source:
- 2x Renogy Eclipse 100W Solar Panels wired in parallel
- EPEVER 30A MPPT
- 45A fuse
- Positive Busbar
- Switch
- 100A fuse
- 100Ah Lithium Battleborn
- Shunt + AiLi Battery Monitor
- Fusebox + negative busbar combo
- 1-2 LED's (thinking mostly AA battery powered lights)
- Water Pump
- Vent Fan
- 12V Cigarette Lighter (to power laptop charger)
- 12V USB Charger or another cigarette lighter for mac charger with USB outputs
Minimum Loads:
- Work Laptop Charger: 90W/12V = 7.5A
- Work Phone Charger (12V USB): 6W/12V = .5A
- Fan: 36W maximum/12V = 3A
- Total Minimum Load: 132W/12V = 11A
- Work Phone Charger: 6W/12V = .5A
- Verizon Jetpack: 6W/12V = .5A
- Mac Laptop Charger: 90W/12V = 7.5A
- Personal iPhone Charger (from same Mac charger): 20W/5V = 4A
- LED Lights: Might go with battery-powered lights but just to budget for some I'd say, 60W/12V = 5A
- Water Pump: Unsure, haven't checked the existing pump, but let's say 35W/12V = 3A
- Total Maximum Load: 343W/12V = 28.5A
Daily Minimum Load:
- Work Laptop for 2 hours: 180Wh
- Work Phone for 2 hours: 12Wh
- Fan on low for 8 hours: 144Wh
- Total Daily Minimum Load: 336Wh/28Ah
Daily Maximum Load:
- Total Daily Max Load: 1000Wh/83Ah
Questions:
- Is this a fair assessment? Would anyone add/modify/remove anything in that?
- Is 200W enough to recharge the battery after a day of average use (assuming "average" to mean somewhere in the middle of min/max loads)?
- Are my fuse and wire gauge specs accurate (no wire should be over a few feet, with exception of the fan wire and solar cables)?
- Is there any way to charge safely from a 60A-rated alternator? I'd considered B2B but the lowest B2B I can find is 20A, which seems high for my alternator.
- Is there any way to charge the battery itself from shore power, or is shore only capable of charging inverter appliances?
- Is the switch placement (after MPPT positive wire) correct if my intention is to use it as a solar shut-off switch in case I want to make modifications to the battery or load components?
