I am thinking to wire bms in a weird configuration for my battery, and would like to know if anyone had similar setup.
I have two 24v DIY batteries and they have been working well. Each is wired as 8s 24v with Daly smart bms, and all 16 cells are identical in capacity and size.
Now I'd like to make 16s 48v battery. A 16s48v bms should be used for this setup normally. However, I like to use the existing 8s24v bms for new 48v battery. To do this, I will wire bms to every OTHER cell, instead of every cell. In such configuration, bms should show 8 x 6.4v (48v battery) instead of 8 x 3.2v (24v battery). I will need to double all voltages in bms settings. For instance, charging limit to 7.3v instead of 3.65v.
Does anyone think this configuration would work?
