Can grid-tie solar inverters run on batteries instead of photovoltaic panels?
My question is can I replace the solar panels that are connected to my grid tie (on grid) solar inverters with similar voltage batteries?(Like hooking up batteries to the terminals where solar panels go)
3kw - 260ish volt on DC (VMP) The minimum operating voltage on my inverter is 160v
I charge my batteries using a separate MPPT charge controller and it doesn't have to be
(solar + batteries), it can be (solar or batteries)
Like morning 8-4 solar and evening 4-8 batteries
Is there any way to make this arrangement work? Converting on-grid inverter to battery powered inverter when the sun goes down while making sure no power goes to the grid
"My inverter (similar mine is 3kw) -https://www.upsinverter.com/product/3-6-kw-utl-on-grid-solar-inverter-2/?gad_source=1&gclid=Cj0KCQiAz6q-BhCfARIsAOezPxk2TD-TATgqNts8IZNbKAeI6ndOUcC7ojeKAJExrgs7JV3a6qbhKKIaAuDVEALw_wcB
I have a 3kw on grid system connected to my utility and the inverter has a current limiter functionality to make sure no power goes to the grid, the inverter doesn't provide any more power than 3kw even during surg which the grid takes care of
Reasoning - No net metering option available from my utility and I cant switch as well. I don't wanna spend extra on additional hardware all the hybrid inverters available to me have only 5 years warranty my inverter has 12 + 3 = 15 years and it's cheaper as well (don't know how or why) as mentioned in the above link the inverter already has a power limiter functionality built in (has a split core transformer aka clamp meter to measure the current coming into my house and providing the exact same power or ever so slightly less (upto 3kw) such that none goes to the grid yes it means that it throttle itself down making it not utilise power available to it but since no net metering is there it's wasted any ways.
My Need - I want the inverter to supply upto 3kw to my house when ever needed either from panels or batteries and any load exceeding this can be drawn from the grid (eg. Surge from water pumps)"
