BrickedKeyboard
- May 2, 2021
- 61
So I noticed many people complaining of bugs in parallel mode, and I noticed it requires a rat's nest of wires and setup. (for both the MPP and growatts brands)
So I thought : why not use a large 12k watt split-phase ffor the 'main' house inverter, and put the EV charger on a separate 1 breaker subpanel. It's not even hard just move the wire over a few inches to a different subpanel, they are $25.
Then use a separate 240 volt only 5-6k watt AIO inverter with it's own solar string.
So you have 2 different inverters, they don't talk to each other, they have their own solar panels, and each is charging or pulling energy from the same battery bank.
Will this work or is there a 'gotcha'?
