First time DIY solar, has been running fine since I turned it on in May.
I have learned that the actual output of the PV array @ the Charge Controller is less than the published numbers, due to normal system losses.
Charge Controller is the 100A- 600vdc version of this:
It maxes out @ 6kw.
Spec sheet says “allowance for over-sized arrays”, whatever that means???
There are two strings of 8 - 365watt panels, (REC 365AA) for a total of 5840 watts.
I have never seen more than 5200 watts, as per the losses.
Too many clouds here in Summer, so the efficiency and charge rate of the batteries suffers.
But if I had more PV, charge rate would be fine, even w/ clouds.
I can add 3 more panels to each string, (total - 11 per) and still stay within the voltage limit of 550VDC.
Not sure what the Winter temperatures will do to the 44.0 voc.
It can get into the 30’s here for a couple of hours, on the coldest day of Winter, just before sunrise.
Will know in about 5 months from now.
11x44.0voc = 484vdc.
12x44.0voc = 528vdc, too near the limit.
But 11x365watts is 4015watts per string, total of 8030 watts.
Not sure how to estimate the system losses, but if I use 11%, the Charge Controller could still see 7100watts.
Do you think this is OK, or will every molecule in the CC explode @ the speed of light?
Conext MPPT 100 600 Charge Controller
The Conext MPPT Charge Controller offers optimum system performance for solar installations, with flexible installation of large PV arrays.
solar.schneider-electric.com
It maxes out @ 6kw.
