I have a Jackery 1500 and 4 - 100 watt solar saga panels. On our 25ft RV trailer we currently have a 12 volt Deka DP27 battery as our 12 volt source. I have a couple questions as a newbie to solar.
1) Can I take the wires that currently go to the 12 volt Deka battery and make connections to connect those wires to the Jackery 12 volt cigarette socket bypassing the Deka battery all together? (Would reconnect the Deka battery when traveling for brake and tail light functions) . I was originally going to plug the camper 30amp shore power into the Jackery but realizing loss using the AC has me thinking if there are reasonable alternatives.
2) We purchased the camper new 12/21. The dealer stored the camper till we picked it up the end of March 2021. Dealer stored the camper outside (freezing) with the battery attached. Needless to say the Deka battery was dead on pickup. We would like to get another battery for camping this spring. We cannot go the lithium route due to costs involved in switching. We have been considering a single AGM battery.
a) Does any one know if the AGM will charge while we are driving like the current Deka battery does? The trailer plugs into a 7 way plug on the truck.
b) The camper has a WFCO WF-8735 converter. (I attached the specs for the converter. ) Can we keep the current converter if we get an AGM? Will this converter recharge the battery when on shore power like it does the Deka?
c) What AGM battery do the experts recommend as a single battery for an RV? The battery will only be used to power the refrig on propane when we don't have shore power. Not a lot of draw.
I appreciate everyone's input. There is so much to learn with solar.
betty
betty
