Can I connect utility to generator port on hybrid inverter?
Lazeringkids
Can I connect the grid to the generator port on hybrid inverter? Will this damage the inverter? My thoughts are I can use the grid as back up when I don't have enough solar/battery power. I'm looking for ways to avoid back feeding the grid. I bought the growatt SPH 10000 because it's affordable and comes with a 10 year warranty for those wondering why not just use off grid inverter. Thanks in advance for any help
So assuming that the unit has three AC circuit options: grid, generator, and AC out? Probably would work but I’d breaker/fuse it for the generator input rating of the growart AIO
Yes it has the 3 you mentioned. Id think this would work, just looking for other people's opinions and if anyone is currently doing it. Thanks for your response
Inverter's with two AC input ports, one for grid, one for generators, often allow a wider AC frequency range for the generator AC input port to allow for sloppier generator frequency tolerance.
If the inverter does exporting to AC input, backfeeding, it is usually blocked for generator port to avoid pushing power to a generator. Some units have an external CT sensor for grid port to allow referencing back feed to main breaker panel grid input to allow export supplementing to main panel breaker loads while avoiding back feeding to utility grid.
Other than these items you can put grid on gen port.
Putting generator on the frequency range restrictive grid port may prevent inverter from sync'g to generator. Sometimes the default freq ranges can be adjusted by user to widen out the acceptance range on grid input.
Widening frequency acceptance range can increase the inverter synchronizing lock time a bit because it has to try a wider frequency matching range in the initial lock search scan range. It also can increase the anti-islanding release time for the inverter.
