RDuke
Hi all,
In another post, it was mentioned that it is possible to disable the heat strips in an air handler so my generator can run the pump without the high
current heat strips causing issues. Now that freezing rain in eminent in my area, it is something I would like to understand better.
My system is a two year old 4 ton Rheem heat pump with 10 KW heat strip in the air handler. My assumption is that defrosting is time based, temp based or both. So how can I disable the heat strips, is it a matter of removing the 240V wiring to the heat strips ? Or can it be done using the control wiring to the air handler? I don't know what intelligence is built into the air handler, and whether it will fault if the coil is an open circuit. I guess it is one of those cases where a "dumb" air handler is an advantage.
Please advise if you have any thoughts. I realize the coils could freeze up, but I can monitor for that.
Thanks in advance
---Update---
I think I may have figured it out since I found the documentation in the attic with the air handler. The documentation says if blowing cold air is not an issue, you can run max efficiency by not connecting a wire to the W1 input on the air handler. I think that may work. If anyone thinks otherwise, let me know please. It is a two stage system so there is a W1 and W2, and a Y1 and Y2. I am thinking the W2 is not connected, but I have not taken it apart yet to verify.
Thanks in advance
---Update---
