Hi all,
I'm pretty new to solar. I have collected some things over the past few years. I'm experimenting in my back yard with off grid solar setups. This is not critical by any means, I'm perfectly fine with my grid power, I'm just a hands on learner and want to start learning for possible cabin scenarios, etc in the future. I would NEVER consider grid tying or anything stupid. I was a science major in college and took physics (although it's been a while). I'm in CT if that matters, as far as temps, think New England.
I have these components:
(10) Trina 250w Panels (older, I'd say 15+ years maybe?, bought off of FBMP, not sure if they are putting out what they are rated for)
Renogy Wanderer 30amp SCC
(2) Duralast 12v Deep Cycle Marine Batteries
Energizer 2000w Inverter
various fuses
1/0 gauge for inverter to battery.
10AWG for panels to SCC and all my other connections
*I'll list the specs and post pics below
I'm reading as much as I can. A few things get confusing. Tried my best to do my own due diligence before posting, but I'm still a bit confused on a few things.
My plan was to hook up one or two of the solar panels to the SCC and just see how much electricity I could generate, plug in a few lights, charge a laptop, etc mostly just for fun and the learning experience in hopes that one day if I buy a cabin I can build my own system to power it.
I'm thinking my SCC is my weak point. according to renogy's site, the SCC can only handle 25v PV input max. One of my trina panels is Vmp=30.3V and Voc=37.6V.
are 30ish volt panels designed for 24V systems? I'm gathering that you want your panel array's voltage to be slightly above your battery bank's voltage?
Can I "overpanel" this SCC? I just want to run one panel into the SCC. 25V max on the SCC but my panel is 30mp and 37oc? Will this harm the SCC? Bear in mind, it's a PWM.
My thoughts right now are to buy this MPPT SCC:
60A MakeSkyBlue
My energizer inverter says 12V, so that means I can only run 12V battery banks, correct?
So if that's the case, the MakeSkyBlue MPPT can only handle 720W for a 12V battery. My Trina panels are 250W max so would running 750W be bad? or is that what is considered "overpaneling?" The MakeSkyBlue also lists 20-80V as the Voc for a 12V battery. 3 of my Trina panels in series would be 112.8V. According to the specs above this would exceed the max Voc for both the 12V and 24V battery bank. Would I have to run a 48V battery bank?
And finally, the inverter being made for 12V only? This means that if I wanted to experiment with 24 or 48v systems I would also have to swap that out as well, correct?
The other aspect of all this is how much more money do I have to spend to just to experiment??? lol. Not trying to be cheap. Spending the $75 on the MPPT is within budget. But now I'm worried I might have to change all of these components to work with my panels. I'm fine running one panel for now, 3 ideally though. or if some type of parallel config makes more sense, I'm open to that. It's just experimenting. I don't have specific needs.
I apologize in advance. I know I'm a little all over the place. My head is spinning from all the stuff I've been reading the past few days. Any help is appreciated. Thanks in advance!
____________
Specs and Pics are below:
Specs of my components:
__________
TrinaSolar Panels (panels are old)
TSM-250PA05.08
Maximum Power(Pmax) 250 W
Maximum Power Voltage (Vmp) 30.3 V
Maximum Power Current (Imp) 8.27 A
Open Circuit Voltage (Voc) 37.6V
Short Circuit Current (Isc) 8.85A
Maximum System Voltage 600 VDC
Maximum Series Fuse 15 A
Minimum Bypass Diode 15 A
Fire Rating Class C
________
Inverter
Model EN2000
2000w
17.9 A
4000w peak
_____________
Renogy Wanderer
Model CTRL-WND30-LI
PWM Charge Controller
30A
Max PV Input Power 400W
25V max input (per website)
_____________
Batteries
(2) Duralast Marine/RV Deep Cycle
Model 27DC-DL
12V
840 MCA
180 RC
~115 Ah?
various fuses
60A MakeSkyBlue
- Maximum PV Array Power:
- ≤ 720W Panel for 12V Battery
- ≤ 1440W Panel for 24V Battery
- ≤ 2800W Panel for 48V Battery
- PV Array Open Circuit Voltage (Voc):
- 20V-80V for 12V Battery
- 37V-105V for 24V Battery
- 72V-160V For 48V Battery
____________
__________
TSM-250PA05.08
Fire Rating Class C
________
Inverter
Model EN2000
2000w
17.9 A
4000w peak
_____________
Renogy Wanderer
Model CTRL-WND30-LI
30A
_____________
Batteries
Model 27DC-DL
12V
840 MCA
180 RC
~115 Ah?
