I bought a basically new Growatt SPF12000t DVM/MPV for absolute peanuts and I'm planning to connect a subpanel to it to power some specific circuits in my home on battery during peak hours and to charge the batteries over night when the power is crazy cheap. My question is very simple. Is it proper to run both 220v loads as well as 110v loads off of this inverter simultaneously? My assumption is that this is absolutely fine, but when trying to research this, the rabbit hole spiraled about LF transformer based inverters(such as this one) vs transformerless inverters and imbalanced loads on the different legs of the output etc... and then I become a lot less sure.
I just want to make sure I wouldn't be doing anything unsafe by hooking up a sub panel and running a 220v circuit as well as a couple 110v circuits at the same time. Is there anything I should be aware of before running a setup like this? Thanks everyone for your help!
Apologies if this has already been discussed here. I have searched as best I could and did not find the answer.
