Can I set 2 333 VOC panel strings to my 6000XP?
Itzzbazz
USA
I want to double check that it’s possible to have two 9 series strings of Hyperion 395W Bifacial Solar Panel (Black) | Up to 495W with Bifacial Gain (That have about 37 VOC each). To a EG4 6000XP Off-Grid Inverter | 8000W PV Input | 6000W Output | 480V VOC Input | 48V 120/240V Split Phase | All-In-One Solar Inverter that as two MPPTs, each string of panels in one.
I’m just confused as to if since each string of panels isn’t inputting more then 335V VOC and each are connected separately… am I still within the 480v VOC of the 6000XP? Or do I need to decrease the number of panels or yes add an additional 6000XP?
Idk if it matters but I’m planning to use a EG4-WallMount Indoor Battery | 48V 280Ah | 14.3kWh | Indoor | Heated as my power bank.
Please help.
