Hi there, as SplitUniverse said,you might be able to put with another off grid inverter together,if the software allows you can run them into back-up mode which depends on the software but is not really an complete off grid situation(there might be even some power restriction on the back-up mode).I am running completely off grid and I've chosen an inverter which has been designed for off grid-even if now accept to be connected to the grid- in that way the system is running sufficiently without any surprises....Having more components in a system,as necessary is not really advisable....Best regards Frank
