In that case probably not. The AIO's from Growatt and MPP both seem to require the "grid" to be the same voltage as their output, so if you're putting 220v out you have to put 220v in.
If you can imagine what would happen when you've got your 110v plugged in and your batteries get low, the AIO would automatically switch the supply from battery to "grid" and all your 220v output would suddenly crash to 110v, which is a "Bad Thing".
