My Grid Tie will be peak 29.8 KW. I see the 33.3 KW Solar Edge Inverter. See attached specs. Can I wire this to the grid? Do I connect to a 220/240 Vac circuit? Or some how create a residential 480Vac circuit, would the Utility see my output correctly? I have 98 panels: 310W, 36.38V, 8.52A. My latitude is 37.95. I will be fixed tilt at 32 degrees. Will I ever peak near 29.8KW? I don't understand planning for inverter operating range of 840-1000Vdc with respect to varying output during the day/year. So can I grid tie this inverter and do I have to stay above the minimum of the 840-1000Vdc operating range and how?
