I sought an answer a couple of days ago at the end of a long thread about my solar system (batteries/BMS) failure.
Can I use one new 12V 100Ah LiFePo4 battery with my existing (3) 150Ah batteries . . . if I can repair those 3 batteries with new BMS units (wishful thinking)?
A "no" pretty much means I would be wasting $700-800, or more. to "get by" for a month or two buying a new battery.
I searched a lot on the Forum. I found several discussions that seem to indicate using different Ah-size batters in a bank is possible. But honestly, the technical references and other uncommon terminology lost me before I could find a simple definitive answer of "yes" or "no"? (Or, find qualifying parameters that would lead me to a decision.)
I'm desperate because I've been without batteries boondocking for many weeks and my tolerance is exhausted. (Bought a cheap Walmart SLA for overnight power for alarms, fridge, etc.) Use solar for things when there is sunshine, but I do not have microwave and other appliances.
I am about to order a single 12V 100Ah LiFePO4 battery to try to muddle by for a month or two.
I am just looking for a "yes," it can be done, or a "no," not possible.
If yes, I'll buy a better quality 100Ah battery.
If no, I'll go as cheap as I can and, sorrowfully, consider it a throwaway.
Or, should I only consider buying a 150Ah battery so I can be used in a bank, if my dead 150Ah batteries are repairable?
I will appreciate any guidance,
Thank you, again.
Jim S.
Thank you, again.
Jim S.
