I'm needing so advice from you guys or gals on my power wall set up. I bought a set of the used LiFePo4 BYD 24v 5.63 kwh 220 ah battery modules from tech direct. I'm connecting them for a 48v system I have not capacity tested them yet. The specs on them are
BYD module LiFePo4 cells
Cell over Discharge = 2.50v x 16 cells = 40.0v
Cell over charge = 3.65v x 16 cells = 58.4v
I just came across a super deal on a complete low mile (63,000) 2012 Chevy Volt battery module for 400.00 So I had to purchase it for the price. I know I can break it down to make 8- 48v modules but the problem I see with using them with my BYD modules is the voltage difference's the byd battery will be set up for 48v with 16 cells the chevy volt will be set up for 48v but only 12 cells. I do not want to break the volt modules apart to reconfigure.
Chevy Volt module Lithium Ion LG Chem cells
Cell over Discharge = 3.00v x 12 cells = 36.0v
Cell over Charge = 4.15v x 12 cells = 49.8v
So if I connect these to my system together in a 48v configuration I want have a very wide usable voltage range. 1 can't go below 40.0 volts and the other can't go above 49.8 so that will only give me 9.8 volts to work with and that is at the low limit on 1 battery and the high limit on the other battery which I would not want to do.
How can I make this work using both sets of batteries. Please let me know what would be the best way to set these up to be able to use together.
