OverThinkingIt
- Sep 3, 2021
- 10
I upgraded from a PWM to a MPPT. So far in mostly full sun (some clouds) my MPPT does 6.8 amps and 12.9 volts out of 3 x 100w panels.... sadness?
I'm wondering if the fact that I have my panels in Parallel is the issue? I read something like that.
Should I / Can I hook these 3 in Series?
The MPPT says it take max input 100v... I assume the whole point of the MPPT is that whatever you put in it will be outputted to the proper voltage?
Here is the MPPT https://smile.amazon.com/gp/product/B08GK8NSRB/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
"EPEVER MPPT 40A Solar Charge Controller, 40 Amp Charge Regulator 12V/24V Auto Max 100V Input Negative Grounded Controller with LCD Display for Gel Sealed Flooded Lithium Battery Charging"
Specs for the panels in attached image. They are close.. two are the same brand the third is different brand. All 100w 12v.
Follow up. According to this fella I don't need to fuse the panels if I go in series.
"If the Short Circuit Current of the solar array is less than the Maximum Series Fuse Rating of the solar panel, the array does NOT need to be fused. Fusing this type of array adds no additional protection or benefit"
Any help gratefully accepted.
How/When to Fuse a Solar Panel Array
This blog post is going to teach you how to determine when and if you need to add in-line fuses when designing a camper solar array. Sometimes you need to fuse your solar array, and
www.explorist.life
