EatonPV
I am adding a second Ruixu Lithi2-16 to my system. There are two positive and two negative battery ports on the Flexboss. Can I plug both batteries directly into the Flexboss without using a busbar? Are any additional fuses needed? The Flexboss has an integrated 300A breaker and each battery has its own overcurrent breaker installed.
Also, the battery manual indicates a 140A charge and discharge rate. By adding a second battery can I increase the charge and discharge rate to 250A (max setting on the Flexboss)?
