did search here and full internet search... only found on discussion and it was inconclusive.
can you take:
> two BAD 12v battery that no longer make it much or not at all over 50 percent capacity
> discharge each below 6v.....
> recharge one at a time with an old charger that has a 6v charge setting to 6v.
> wire them together as if they were 6v batts to make a 12v bank
> maybe an inexpensive or two battery 6v balancer be needed for this to work at all?
> use this new bank as a 12v power source?
> charge them as a 12v bank (solar or otherwise)?
> if so could be done with 4 of them and then wired for 24v as if it was a bank of 6v batts put together?
just trying to maximize the use of some old batts I have before disposal. Ive run them thru a battery pulse system numerous times.... they dont improve. If this would work Id use them thru the winter for some light use thru an inverter to say a 1amp at 110v furnace fan
can you take:
