Greenwatts
I have already three Seplos 48100-1101-10C-S16 pcb V14 in master slave setup connected to a Deye 12k hybride and need another BMS for a set S16 LF280k.
The limitation with these 48100-10C is that at the moment the master get a slave, the BMS the discharge limits for all (master and slaves) to <50A or 0.47C as it are 100A and I don't reach the needed 240A for selling to the grid (dynamic hour tariff), even with a 4th set.
For this limitation i got this week firmware V2.9 HW14, at the moment not installed or tested
Is it possible use both with master/slave because Seplos sales which quote me a pcb V16 48200 10C or 10E says:
"Kindly reminded if the BMS-48200 is parallel with BMS-48100, we are highly not recommented,
for this can cause the data to become confusing."
