Hi Fellow Solar Enthusiasts,
I'm in the late stages of installing a 10Kw solar system on my retirement home. The set-up consists of 24 Trina 450w PV panels, 2 separate (NOT in parallel) 5KW solar charger-inverters (MPP Solar PIP5048MKX) and 3 x 200AH 48V LifePo batteries.
In the MKX user manual, it "strongly recommends" using a current limiting device between the battery bank and the MKX. I assume I could use a 250A in-line fuse but think that a 250 DC breaker would be better since it could be used as a disconnect device as well. However and this is where I could use some expert advice, is a DC breaker bi-directional? Since the MKX both charges the battery as well as draws power from the battery to invert to AC, a DC breaker should provide protection in both directions, no?
My rudimentary understanding is that a DC breaker is designed to extinguish arcs when the circuit is broken, so it's not intuitively obvious to me that DC breaker design is inherently bi-directional. In fact looking at the specs of various DC breakers, one side of the breaker is generally labelled as "Load", which is why I am confused when the MKX is both a battery charger as well as an inverter.
Would appreciate some clarification in this area from more advanced solar practitioners.
Thanks very much for your attention.
