Can someone help? Im having trouble trying to power a window air conditioner in my rv. The ac is rated at 670 watts. I have a 1200peak 900 continuous generator brand new from oriellys and it seems to keep throwing the circuit breaker on the generator after running with compressor on for max 3 min. Sometimes withing seconds of thr compressor starting. The air con doesn't have a ground on the receptacle because someone must have snapped it of. Im not sure if that would have any effect on performance.
I also tried on a used 5000watt generator i just purchased with the same results. Second question is. I have a 2000 inverter and 1 deep cycle battery. Wondering if I could plug the air conditioner into the 2000 watt inverter while connecting the deep cycle to a 10amp battery charger that would be powered either generator?Would that be at all possible? I would appreciate some feedback before I make anything worse. This is rough... Just want to cool my family down...Thanks!
