BLUE SKY CAMPER PROJECT
- Nov 3, 2020
- 1
Hi.
I'm working in Japan to install lifepo4 on a camper.
This time I installed 15kwh on a kitchen car with a 16S 48V system.
I used JBD's SP20S005.
It has 3 NTC sensors.
Of these three, one (A) has a sensor cable.
I connected it to the battery terminal.
I don't know the locate of the other two (B / C) sensors, but it's probably on the board.
It's very cold now, so I installed a heat pad on the side of the battery to build a self-heat for the battery.
BMS does not have a heat pad.
However, the sensor (A) connected to the battery terminal warms up, but the other two (B / C) do not warm up, and when those two are below the set temperature, charging stops due to "low temperature protection".
Is there a way to enable only sensor A and disable the other two (B / C)?
I tried to remove two "NTC" check marks (B / C) at the bottom of the setting screen of Xianxiang BMS App, but the behavior does not change.
If the other two (B / C) fall below the set value, low temperature protection will be activated.
Is it necessary to warm BMS?
It is the battery that should be protected, and BMS has a wider operating temperature range than the battery, so it is a problem if the temperature sensor cannot be disabled.
If you know the countermeasures, please let me know.
