JCDerrick
- Apr 17, 2022
- 5
I think I know the answer to this question, but thought I'd confirm since you all have a lot of experience with this subject.
I currently own an Ecoflow Delta Pro + Smart Battery, and I also have a Bluetti AC200Max. We're currently boondocking and I'd like to hook them together to essentially expand my capacity on my Delta Pro. I think the simplest solution would be to use the 30amp DC output on the Bluetti (using the aviator connection to XT60) and then plug the XT60 into the 15amp solar connection on the back of the Ecoflow Delta Pro (the same port as the 'car charger').
I assume that even though the max solar input is 15amps on the Delta Pro, it'll only pull that amount from the 30amp DC port on the Bluetti; is that correct? Or will that waste the additional amperage?
I also assume you could do this in reverse by using the Anderson 30amp plug on the Delta Pro and input it via the solar plug on the Bluetti? I am trying to set things up so I can use both and then hook my solar bank into the 'front' unit, in this case, the Bluetti.
So, in essence, my 800W of BougeRV solar panels would be hooked up to the Bluetti, and then the Bluetti would use the aviation to XT60 plug to input 15A 12V+ into the Delta Pro. Am I wrong, or will that work, thus allowing me to utilize the Bluetti almost like an extra battery for the Delta Pro?
Thanks for any feedback you can provide on this.
