D
Deleted member 9967
Guest
Ok, so I have an adjustable power supply.
It can send out a voltage of anywhere from zero to 16 volts at 30 amps.
If I set the voltage to say 13.8 or even just 13 volts.
Will it be safe to use this as a charger?
As far as I know it will not shut off at any time for any reason though.
It is simply a power supply to supply power to whatever you connect it to.
Second question. Do I just connect the positive from the power supply to the positive on the battery?
In charging is this not reversed?
Thanks guys.
EDIT: And no there is not yet a BMS.
Just a paranoid me testing every half an hour LOL.
Thanks guys.
