What an amazing resource this forum is.
Last year my wife and I bought 3 acres on a remote island near Vancouver and we are starting to build a weekend getaway. The property is off-grid so everything solar has been top of mind. The tiny-house itself will be a 32' diameter geodesic dome or roughly 950sq (including a loft).
Water comes from a well, 140' deep and is fed into a 800 gal cistern driven by a 115v 1/2 hp pump which my 3000w Honda generator has no problem running. This will provide enough water for the season and is gravity feed 300' down to the dome.
I had a 20' shopping container shipped over to help with logistics and serve as a shop and storage area + power center, so this thread could really be cross posted in both sections. I'm still designing and thinking though our requirements for power but narrowing in on a 48V system around 5 kwh which would be terminated in the container and then run 100 feet to a small breaker box under or in the dome itself. The needs are pretty minimal, a fridge, few lights and sound system that draws 11A/110V.
When I first starting thinking about power I was initially drawn to the Magnum Energy MS4048 Inverter but it seems like a MPP solar lv5048 all-in-one seems much more practical and I think I could plug the generator into as a backup.
As for batteries I really like lifepo4 in either a drop in or DIY, but really need to find a good BMS with low temp cutoff (being in BC we get days below zero between dec-march) and we may go all winter without even checking in on the property.
It seems like the longer I hold off the cheaper batteries seem to get, but 2020 will be the year I pull the trigger and setup solar.
Excited to be part of the community and I'll post updates as they come.
Rob
New item by Rob Ellis
photos.app.goo.gl
photos.app.goo.gl
Rob
