MisterSandals
Participation Medalist
This is an unusual suggestion. Did your conversation with them involve shading issues?BougeRV responded that I try to set up 2p3s
3S2P is very common for 6 panels, 2P3S is extremely unusual (cannot say i have ever heard of anybody doing this).
Did you discuss possible SCCs to use?
You've gotten great advice so far; talking you down off the 6P ledge was important. That thinking is from old tech of PWM SCCs. The modern day MPPT SCCs accept array input at higher voltages that is much easier to wire/connect. Higher voltage (actually lower amps), greatly reduces and fewer parallel connections often eliminates the needful fusing.
Your only decision that I see now, assuming you accept 3S2P is how to get 1200W into your batteries.
1200W / 14V charging = 85A
Looking only at Victron, there are a couple solutions: one very big SCC or 2 medium sized SCCs. One SCC is simpler to wire:
It ain't cheap, brace yourself:
Or 2 medium sized SCCs, each accepting a 3S string (not cheap either but offers good redundancy):
Either of these in my opinion would be the premium solution. Top tier product, easiest to use, probably among most reliable. 5 year warranty is MIGHTY nice. Bluetooth and apps are an absolute joy to use for configuration and monitoring.
